i2 export workspaces
Postby FoxSTI on Mon Apr 30, 2018 2:13 am
Is there a way to set the default path of where the workspaces are saved?
or if there a way to export them?
Thanka
FoxSTI
Re: i2 export workspaces
Postby adrian on Mon Apr 30, 2018 12:29 pm
There isn't a way to change the default location of the Workspace directory.
You can export them by going to File>Workspaces>Export>To File. This will give you an archive file that contains all of the information in the Workspace. If you copy this to another computer you can simply double click the file and it will install it in the correct location.
If you are using i2 Standard then the Workspace will be available under the 'Custom' Workspaces on the splash screen when you start i2. Or with i2 Pro you can simply click the open button on the splash screen or go to File>Workspaces>Open
