Account the number of time that something happen
Postby Fermin on Wed Feb 11, 2009 1:44 am
Hi, I dont speak english, but I wait that you can understand me. I seek a expression that it account the frequency, the number of times, that something happen, for example, the number of times that the car is in second gear, etc.
I can do this, but I need five expressions by each parameter that I want know the number of times
Example that I do:
A: 'Gear' == 2
B: time_shift('A',0.001) [Rate:1000Hz]
C: max('A' - 'B',0)
D: integrate('C') [Rate:1000Hz]
Nº of time in 2º gear: (stat_max('D') - stat_min('D')) * 1000 [Rate:1000Hz]
I seek something more simple, this way consume many resources of the PC.
Can you help me?
Thanks.
Fermin
Re: Account the number of time that something happen
Postby OmarK on Fri Feb 20, 2009 3:12 pm
i2 doesn't have a "count" function that you are looking for yet. I usually export data into excel and perform maths calculations as well as produce summary charts and graphs, maybe this could be an option.
OmarK
Postby mangel83 on Thu Sep 27, 2012 7:00 am
3 years after the original post I wanted to know if the function was included, i.e. to count the number of gearshifts per lap.
Is it possible?
mangel83
Postby Martin on Fri Oct 05, 2012 10:05 pm
this is how I count
integrate(abs(derivative('Gear')))
Postby ElectronSpeed on Sat Feb 02, 2013 2:53 am
Martin,
I like your solution.
I was having a problem trying to count RISING edges of a pulsed signal. Ultimately, I took your solution and divided by 2.
Eric Schieb
ElectronSpeed
