Merge data feature
After seeing it mentioned in another thread, I had a bit of a play with the merge data feature in i2. Is there any documentation, or can I get a brief summary, of how the merge data feature works?
On several of our vehicles we have data from a dash and an ECU, where there are often duplicates of engine related channels in the dash but they're logged at a higher rate in the ECU than in the dash - it would be great if when I merged them it chose the data that was logged at the higher rate, but it appears that it doesn't. If I knew how to get reliable and repeatable results from merging data files I could greatly simplify the CAN bus streams between dash and ECU!
On a somewhat related note, a piece of software that could download from multiple devices simultaneously and apply the same details to all downloaded logs (or just merge them into one log) would save me a lot of copying and pasting of comments and tabbing back and forth between Dash Manager and M1 Tune
