Varience Question
Mon Apr 24, 2017 10:07 am
by killerbee
While comparing laps using variance I noticed a discrepancy between lap time differences and the final variance value at the end of the lap. The difference is over 0.5 sec and I am assuming that they should match fairly closely. What am I doing incorrectly ?
Re: Varience Question
Mon Apr 24, 2017 10:31 am
There are many things that can cause the Time Varience to be incorrect. Here are a few questions to investigate:
Are both laps the same distance, or is Distance Stretching enabled (Tools->Corrected Speed and Distance->Corrected Distance Tab->Distance Stretching. What is the track length in the details compared to the actual (or Corrected) Lap distance/
Have you used Data Offset to move the origin of either of the laps?
Is your corrected Speed accurate (ie, wheel speed calibrations correct, etc.)?
Perhaps you would post a couple of laps in a log file and we could take a look.
