Global vs. Local maps
Postby Brinkley on Fri Jan 23, 2009 1:10 pm
I appreciate everyone's help in the past and hope I can get another answer regarding setting up maths. I am able to go into Tools / Maths / Local to set up a filtering math to smooth out the Lateral and Long G meter. However, this is only good for the one file that is open and associated with this local math.
I don't know how to set up a "global" filter math so that whenever I open up a logged session so that the Lat and Long G is filtered and smoother.
Brinkley
Re: Global vs. Local maps
Postby JamieA on Wed Jan 28, 2009 4:56 pm
I assume you are using i2 pro?? Anyhow, just copy your filter from the local maths area, and paste it into
Global Maths\User
This is where any user created global maths should go.
-Jamie
JamieA
Postby Brinkley on Thu Jan 29, 2009 1:46 pm
Jamie,
thank you once again for your guidance. However, I am using i2 Standard and your instructions worked perfectly.
Enjoy the Tennis
Chad
Brinkley
