Issue with distance and time
Posted: Tue Dec 13, 2016 3:00 am
I have an issue with i2 and the distance/time channels.
I have noticed that my race time and distance was much less than reality.
The following picture shows corrected distance set using "use distance channel":
While the following picture shows corrected distance set using "use speed channel":
As you can see it is not linear, which is strange. When exporting the results, here is a portion where the singularity occurs:
If it can help, I have noticed that every time the distance "jumps", is at the end of the lap!
Thanks in advance!
- Code: Select all
Time Distance
255 1233
255.1 1233.7
255.2 1234.4
255.3 1235.1
255.4 1235.8
255.5 1236.5
255.6 1237.2
255.7 1237.9
255.8 1238.6
255.9 1239.3
256 1240
256.1 1285.5
256.2 1331
256.3 1376.5
256.4 1422
256.5 1467.5
256.6 1513
256.7 1558.5
256.8 1604
256.9 1649.5
257 1695
257.1 1695.5
257.2 1696
257.3 1696.5
257.4 1697
257.5 1697.5
257.6 1698
257.7 1698.5
257.8 1699
257.9 1699.5
258 1700
Thanks in advance!
