I think the Zooming on the GPS track needs to be complimented with Panning.
I want the section I am looking at to be in the center of my screen not wherever i2 thinks it needs to be.
Do you have an example of what you mean? i2 simply zooms in far enough to show you the entire selection on the page.
Regarding the track report, same concept, maybe I want to zoom into a section of the track to look at the report with less clutter.
I do sort of see what you mean but that isn't what the track report is designed for. It is supposed to be a general overview of the entire lap. If you want to do more detailed analysis the you should be using time/distance graphs.
I think the track report is not what I thought it would be in my opinion. I thought I would be able to click on it (anywhere) and extract any channel information at that point.
You can simply have a time/distance graph up on the same worksheet, then you can see the value of any channel where ever you click. So for example, in the below screen shot I have clicked on the apex of a particular corner and looking at the time/distance graph I can read the maximum lateral G. I could also have set this up in the track report to give me the same information.
- Track Report.png (1.45 MiB) Viewed 20416 times
Not just Max/Min, Average etc at "random" (seems to me)
When you create your track map you also generate the sections, ie turn 1, 2, 3, straight 1-2, 3-4 etc. this is what the track report uses when calculating min/max etc.
For instance I want to see my speed at the end of the straight (gray section) I see to way to do that at the moment in the track report. All I can do it pull up a gauge for the channel I want to see and watch the gauge.
Assuming that you consider the 'end of the straight' to be the point at which you hit the brakes and that you have been full throttle for the length of the straight then that's exactly what the track report is giving you.
