Log File Time Scale
Log File Time Scale
Postby CarloL on Tue Nov 08, 2016 7:15 am
Hi
I have a very large log file spanning over weeks of data (59 mb), how do you narrow down the time periods?
It appears it is just 350 M/S of data , can you toggle the data to identify the time period it was captured?
I put in a new fuel regulator yesterday (Nov 6th)and want to check the AFR's after I took the car for a run
Log file
https://1drv.ms/f/s!Ao-FTTt3GMhrg4Qb72PNqQPeKitomQ
thanks
CarloL
Re: Log File Time Scale
Postby David Ferguson on Tue Nov 08, 2016 8:56 am
Are you asking how to "zoom in" on the data using I2?
-- click on the graph at the area of interest and press the up arrow key on the keyboard.
Or you can double-click and drag the cursor to select a range to zoom into.
You can drag the time scale at the bottom left and right to "scroll" through the data.
This file seems to be about 520 minutes (8.6 hours). Have you considered erasing the ecu/dash data after downloading?
Are you using the "Engine" Workspace -- that will use time for the X-axis, instead of distance. If you are using a workspace with distance, then perhaps you need to calibrate your vehicle speed -- as the maximum in this file is only 13.9 km/h which is pretty slow :)
Last edited by David Ferguson on Tue Nov 08, 2016 9:17 am, edited 1 time in total.
Postby CarloL on Tue Nov 08, 2016 9:11 am
Thanks David
I forgot to erase the data , it is a road car so I rarely look at the logs once she is running Ok
CarloL
Postby David Ferguson on Tue Nov 08, 2016 9:18 am
oops, updated my original response while you were responding.
Postby CarloL on Tue Nov 08, 2016 10:43 am
I am using the Engine" Workspace , no wheel speed sensors are connected yet or GPS , not too sure how it can calculate speed
Will mess around with the other work spaces
CarloL
