do logged Knock1/Knock2/Knock3/Knock4 indicate cylinders #1/#2/#3/#4, or in firing order (for example cylinders 1-3-4-2)?
Scott@FP wrote:Tools/Channel Mappings. Rename the channels in Channel Mapping by firing order, log data channels are created by output order and need to be remapped to proper cylinder. In the case of common 4 cyl firing order 1-3-4-2 Knock 1 = 1, knock 2= 3, knock 3 =4, knock 4 = 2
Applies to all firing order effected outputs I believe.
Scott@FP wrote:You need to do this to get the cylinder # correct for the SKM/OKM in i2
