Upgrade i2 Std 1.0 to 1.1
PostPosted: Thu Jul 28, 2016 10:32 am
by AdamW
I just installed i2 Std 1.1 and found none of my customised projects and things like user maths etc are carried over. Is there no way to "import" these customisations over from 1.0 or do I have to manually set up every project and formula again from zero?
Re: Upgrade i2 Std 1.0 to 1.0
PostPosted: Thu Jul 28, 2016 12:32 pm
I don't think there is a way to do this with I2 Std. With i2 Pro, you can open a workspace, and there is an import button that allows you to pick I2 1.0 projects.
I2 Standard only allows you to work on a Circuit/Drag/Engine/Rally workspaces.
If you were up for the challenge, you could try this:
- install I2 Pro, use it to open your I2 Standard 1.0 projects and save them as I2 1.1 workspaces.
I2 Standard 1.0 keeps these projects in somewhere slightly hidden (I can't find it right now...)
I2 Standard 1.1 keeps the Workspaces in C:\Users\<username>\AppData\Roaming\MoTeC\i2\1.1\Standard\Workspaces
Hope that helps.
PostPosted: Thu Jul 28, 2016 1:13 pm
by adrian
David is right, i2 standard won't do the conversion for you however i2 pro will.
In i2 Pro (Needs to be a 1.1 version) go to File>Workspaces>Open. Now click import and select "i2 1.0 project" from the drop down. Now go to C:\Users\<username>\AppData\Roaming\MoTeC\Standard Projects\<Project Name> and select the project file.
Once that is imported go to Documents\MoTeC\i2\Workspaces and copy the folder of the workspace you just imported.
Go to C:\Users\<username>\AppData\Roaming\MoTeC\i2 Standard\Templates and paste the folder in.
PostPosted: Fri Jul 29, 2016 12:05 pm
by AdamW
Hey thanks guys, sounds straight forward enough, I will do a back up first then give it a try...
Re: Upgrade i2 Std 1.0 to 1.1
PostPosted: Tue Aug 02, 2016 4:42 pm
by AdamW
Reporting back for anyone else that needs this. Above procedure posted by David Ferguson & Adrian worked nicely and all my user maths and projects translated intact. The only extra bit of info I will mention is the workspace location for i2 std 1.1 is slightly different to what Adrian suggested - at least in windows 7 that I am using...
Mine were located here by default:
C:\Users\<username>\AppData\Roaming\MoTeC\i2\1.1\i2 Standard\Workspaces
Also I updated the title of this thread since I just noticed my typo...
