Importing Gear Ratio from ECU Log File
I'm using i2 software to calculate my clutch slip. To do so I need several data points (Engine RPM, Gear, Transmission output speed) which are part of my log file. I've set my gear ratios in my ECU, but they are not imported into i2 when I open my log files.
To get Clutch Slip to work, I had to re-key the ratios under Vehicle Details (i2).
Any idea why the ratios are not imported. I've looked into the setting in i2 and Motec ECU manager and the instructions say this info should be part of the log file. Any help is appreciated.
Versions
ECU Manager: 3.54E2
i2 Analysis Software: 1.1.2.0544
Versions
ECU Manager: 3.54E2
