Lap Editor Question
Tue May 31, 2016 12:52 am
by killerbee
I have been trying to figure out how to remove multiple laps using the lap editor. All I can select is a single lap at a time. Is there a way to do this ?
Re: Lap Editor Question
Tue May 31, 2016 2:11 pm
by adrian
It is only possible to select one lap at a time. I have added this as a feature request.
Sun Jun 12, 2016 11:49 am
by killerbee
The reason I am asking is that we have had some difficulties with laps generated using a GPS beacon stored in the dash (SDL3). Occasionally, it is clear that the dash generated laps do not correctly show the car's position on the track. It makes a hash of lap comparisons also. The only way I have found to clean things up is delete all the dash generated lap beacons and regenerate them in I2. I must be doing the dash setup wrong but I have watched the webnairs associated with the subject and have followed the instructions.
Tue Jun 14, 2016 9:41 am
by adrian
Are you actually getting beacon points at different parts of the track? When you say 'not correctly showing the cars position on the track' are you looking at a track map or a GPS track map?
The best way to setup the GPS beacons is to first get some logged GPS data from the track. In i2 move the cursor to the start/finish line and then copy the lat/long coords into the venue details of SDL3 Manager.
One other thing to check is that your detection radius is at least 10m.
