Importing data from other codes
Postby Monstrobolaxa on Thu Oct 23, 2014 2:12 am
Hello all,
I'm trying to import data from two other codes into Motec to compare real world data, with an in-house simulation code with simulator (rfactor - Motec) data.
Is there any plugin or functionality that I can use to import data from other codes? What formats are available?
Both other software can export as .csv files, this appears to be the common ground between the other two....so can I import into Motec?
Monstrobolaxa
Re: Importing data from other codes
Postby Turby on Fri Oct 24, 2014 12:07 am
To help you achieve what you want what about purchasing a Motec logger / display / ECU which has I2 Pro logging enabled and then purchase the optional I2 API license ?
Turby
