i2 Slowdown - No Distance in Distance channel.
Has anyone else experianced a big pause when you have a project or template open and it is based in distance mode (F9 toggle).
Load a log file which has no distance actually travelled.
( For us this could be a workshop fireup or bench test, so it happens quite often)
On all of the laptops I could test here, we get a big pause whilst i2 works out that there is no distance travelled,despite there being a distance channel logged.
After the puase you can F9 change the screen to a time based layout.
Has anyone else seen this problem and if so, is there any way to work around this 'zero distance' issue.
(other than toggling to a time based layout before opening the log file)
Cheers, J.
Cheers, J.
