Data sheets and Details (Ctrl D)
I am trying to understand (or receive advice) on saving setup data using i2Pro.
Before heading out, we record the cars specific setups: Front Swaybar %, Rear Swaybar %, FL Compression, FL Rebound...you guys know this. When the session is complete and data unloaded, I want to store the data in i2 Pro. So the Question is, how is this approached in i2 Pro.
Do most hand write the data, then when I download a session, manually put it into custom fields in the Details Custom Fields along with weather, temperature that is in the other areas?
I, for the life of me, cannot get the concept of using setup sheets. Do data sheets and the column names somehow link via channels to the Details in i2Pro?
