Data sheets and Details (Ctrl D)
Postby TEDean on Mon Apr 14, 2014 7:27 am
I am trying to understand (or receive advice) on saving setup data using i2Pro.
Before heading out, we record the cars specific setups: Front Swaybar %, Rear Swaybar %, FL Compression, FL Rebound...you guys know this. When the session is complete and data unloaded, I want to store the data in i2 Pro. So the Question is, how is this approached in i2 Pro.
Do most hand write the data, then when I download a session, manually put it into custom fields in the Details Custom Fields along with weather, temperature that is in the other areas?
I, for the life of me, cannot get the concept of using setup sheets. Do data sheets and the column names somehow link via channels to the Details in i2Pro?
TEDean
Re: Data sheets and Details (Ctrl D)
Postby TEDean on Mon Apr 21, 2014 12:14 am
Anyone? Is there another forum that might give some insight?
TEDean
Postby Hiwind on Mon Dec 29, 2014 5:06 pm
this is a great question .. keen to hear what insight you Motec guys can offer
I currently use the details page and put this in with weather etc...
but it would be much better/faster/complete to be able to use excel
thanks
Matt
Hiwind
Postby David Ferguson on Tue Dec 30, 2014 6:53 am
The Excel Setup sheets are great for numerical setup data that you may want use with math channels, also for data that you just want to keep associated with a range of log files. Start by creating a Setup Sheet for a specific Dash/Vehicle using the I2 menu Tools->Setup Sheets...
There is a column for each setup sheet channel, you can duplicate columns and add your own channels. The times/dates in the first columns need to be in increasing chronological order, but you don't have to fill in every column, only when something changes. I2 Pro will find the date of a given data file, and find the latest setup data for that date (using previous setup data if necessary for some or all of the channels). These channels are available for you to display in reports, use in math channels (ie. use damper displacement x the fitted spring rate to approximate the sprung load). Apparently you can also use text values from fields (found this using the I2 Pro 1.1 Help file for Details).
I also use the vehicle details to keep some of this info as well (things like brake pad brand/compound, rotor thickness, damper valvings and adjuster settings). I like using the vehicle details as this can be prepared prior to an event. And it automatically carries forward unless I change it.
Weather info is best added into the appropriate fields created in the log file details available from within I2.
If you would like some help getting your setup sheets working properly, I am available to help via email / phone or shop visits.
ferg@veracitydata.com
Postby Yusuf on Fri Feb 20, 2015 9:50 am
I am new user of Motec i2 software and trying to understand the variables which coming from Exported data (all). There are like 72 variables such as Device up Time, CAN i Receive Error count, VCS Diag, VCS Temp, etc. Is there any manual or book that gives definition for each of these variables.
Thank you
Yusuf
