track maps
track maps
Postby sphilips on Sat Aug 03, 2013 8:23 am
I can't get any decent track from my logging files. Can Someone tell me what I do wrong.
20130512-0213502.ld
(1.01 MiB) Downloaded 1093 times
sphilips
Re: track maps
Postby Holmz on Sat Aug 03, 2013 10:50 am
I was on the blower to Darrin @ MoTeC a couple of months ago...
With i2Pro it is not as easy as it use to be where one could load in the track map.
So I have not progressed at all.
Re: track maps
Postby AdamW on Sun Aug 04, 2013 8:09 am
sphilips wrote:I can't get any decent track from my logging files. Can Someone tell me what I do wrong.
Your main issue is your speed channels have no units. Use the 'channel mapping' to add speed units to your ground speed channel then you will have enough data to make a map.
Also, I dont see any lap beacon in your log - was this a closed circuit or a rally/hillclimb type track?
Motorsport Electronics Ltd.
AdamW
Re: track maps
Postby sphilips on Sun Aug 04, 2013 5:21 pm
I have a log files where I have units on the speedchannels.
I don't have a beacon.
Isn't it possible to insert a laptimetable, and use this?
sphilips
Re: track maps
Postby AdamW on Sun Aug 04, 2013 8:11 pm
sphilips wrote:I don't have a beacon.
Yes, you can use the lap editor to insert a manual beacon and use either lap times or track distance to divide the session up into laps but it will be pretty tough going getting it all to work without any fixed beacon though.
AdamW
