External maths
I'm trying out the sample external maths and i can't seem to get the "function" versions to work, either the C++ or the VB dlls. When i do "add plugin" and select the dll it doesn't appear in the list. Is there something missing from the samples to make them work or am i doing something wrong?
The VB "plugin" version with the simple sine wave works as expected. is there a C++ "plugin" sample available?
also, if i add the simple sine wave plugin twice and select a different frequency for each instance, i can't get both to appear in the graphs, it'll only allow me to select one at a time .. is this a limitation because the channel name is the same for both? any way around this?
i2 pro 1.0.3.106
-nigel.
i2 pro 1.0.3.106
-nigel.
