Setup Sheets
I'm having some issues with the setup sheets. I modified the MOTEC generated one with values from my own setup sheets. All I did was change channel names. Now:
1. Every time I open the setup sheet, I get an error that says "Failed to open 'C:\.......xls' Please ensure you have entered you have entered the correct setup sheet passord in i2"
There is no password.
2. When I try to save the setup sheet in excel, it says "cannot be saved in the current format. To save your changes, click OK, then save it as the latest format. The system wants to save it as an "xlsm" file.
3. So I do that, and then MOTEC can't find the spreadsheet, so my list of constants from the setup sheet is blank.
Then, at some point I2 refreshes and loads all my constants. Even though the filename in the "setup sheet file" box does not match my filename.
I've tried to save it as an Excel 2003 file with an .xls extension, and it does not load the constants from my data source. All marco and active X security has been turned off.
Any ideas?
Also, I'm having a problem with my "rear wheel travel" channel. Its very simple, just 'Damper Pos Rear'*'Rear Motion Ratio'. Damper Pos Rear is a logged channel, and motion ratio calculates just fine. But the resultant is completely nonsensical. For example, at a certain point, I have a damper pos of 6.27mm and a motio ratio of 0.488, but the travel reads -159034.25. Mind you, the trace on the plot does make sense if you autoscale it.
Any ideas on this? I can't upload my customer's math definitions, datasets or setup sheets for confidentiality reasons but I will email them directly to MOTEC engineers if requested.
Any ideas?
