Advice using i2 pro
Hi Guys, I have a few quires regarding the i2 pro software.
To give a bit of background i am using an ACL which logs GPS (position, speed, etc.) from a CAN input using a VBox i also have a VCS recording video (the enable video sync has been ticked) and there are also 7 other cameras placed around the vehicle. The idea is that the VCS will allow me to sync the data to the video and use this to sync the data to the other camera views. To help with the time slip a clock was placed in front of each camera before each test.
Now the issues,
1) the tests we were conducting were in very hill terrain with dense vegetation which caused the GPS to dropout, unfortunately when this happened the ACL recorded a speed of zero and a lat and long of zero which is more annoying, because now when i try and export a Google earth file it gets confused and tries to plot some points of the coast of Africa. This is annoying but the real issue comes when trying to generate a map in i2, I believe i had found a solution which would involve creating a maths channel that would eliminate these erroneous values however this does not work, i think i2 requires an uninterrupted data source to generate a map., can you suggest a way i could address this?
2) is it possible to setup camera vies for all cameras that will automatically load when the project loads?
3) i think i noticed someone else ask this (or similar) question, is it possible to generate the map over the Google earth image in i2. so that when using i2 you can see the google earth image.
Gary
Now the issues,
Gary
