I2 pro overlay questions
To the Motec community
Recently I started using I2 pro for data acquisition to overlay and compare two similar touring cars. Both cars are using a common beacon, running the same track at the same time etc. One of my functions is to summarize the data and sit down with the drivers after every session. It should be noted that I have only been using Motec for two events, so I am still a novice. Typically when overlaying the data I review the graphs for rpm, corner speed and braking. A few questions have come up:
1)For the over-lay is it better to compare the two cars using “Time” or “Distance” for the x axis? Basically I am looking for braking point, entry, mid and exit speeds between the two cars. In other words, who is on the brakes the latest and who carries the higher speed through.
2)For the section time tab, is the reliable data? The reason I ask is that in some case I have seen the data conflicting (I.e. One drivers corner speed is faster on the graph and yet the section time is slower then the other driver). Do any of the other times on the form use the section time tab?
Your help would be appreciated.
Respectfully
Michael L. Thompson
Respectfully
Michael L. Thompson
