I have several questions on the oversteer formula.
edit:
This is the original formula out of i2 (it's the same in Standard and Pro version)
smooth(choose('Corr Speed'[km/h] < 50, 0, sgn('G Force Lat'[m/s/s]) * (('Vehicle Wheelbase'[m] * 'G Force Lat'[m/s/s] / sqr('Corr Speed'[m/s])) - sgn(stat_mean('Steered Angle'[rad] * 'G Force Lat'[m/s/s])) * 'Steered Angle'[rad])), 0.2)
I only adjusted the channel names to the ones we use and filled in the vehicle wheelbase to the vehicle details. On i2 Pro the formula works fine or lets just say it shows a "result".
1. Has anyone experience on using the i2 Pro oversteer formula compared to driver's experience/comments.
2. I want to know how reliable the results of the formula are and in between which range I could say "THIS is now understeering (or oversteering)!"
3. I do supervise another car which only can generate i2 Standard files. When I tried to use the oversteer formula on i2 Standard it refused to work by saying: „Binary operator does not apply to these operands.“
Is this formula too complex for i2 Standard?
Thanks for your answer.
Best regards
Julian
