i2 folder problem and general questions
1) It seems that every time you start up i2, it makes a Motec folder in the root directory of your hard drive. Is there any way to disable this? Under Tools, Options, Video, I've set the folder to be one within the My Documents folder.
2) Is there any way to delete data the way you would in most audio or video editors? Select the area in the time domain you want to get rid of and then select delete. I can't find any way to select the data. The only way I've found is to use the Split Data function.
3) With Histograms, is there any way to determine/specify in the time or distance domain what data they operate on, as opposed to using all of the data in the log?
4) When you place a video on a worksheet, and select Add Video file, the file selection box opens up to where ever you have selected to store logged data, even though I have selected to store videos in a different directory.
