Drag profile questions
Posted: Fri Oct 29, 2010 3:37 pm
Question #1:
Regarding the clutch slip calculation in this profile. One of the requirements is to have drive shaft rpm logged. Is there some way to trick i2 to let one use a math channel as an input instead of the driveshaft rpm channel. I plan on averaging the left and right rear wheel speeds and multiply this by the differential gear ratio to calculate the driveshaft rpm instead.
Question #2:
I've added a worksheet to the profile, but I am unable to add a track report or GPS track on the new worksheet. Is there any way to do this?
Question #2:
