MoTeC rFactor-No Trackmaps Win7
Posted: Thu Aug 26, 2010 10:03 pm
Hi everybody.
Im using MoTeC for about a year now and it worked fine from the first try. Im using MoTeC i2 Pro 1.01.0082 with the rFactorDAQPlugin 1.3.2
It has worked as I said from the beginning. I just had to set the correct directions. Now since 2 months, MoTeC doesnt create Trackmaps anymore and dont even save them anymore into the Trackmaps folder. Before that it has created them automatically and everything was fine.
I have tried everything hint I've found on the internet, also here on the forum but nothing seems to work. I have reinstalled MoTeC, rFactor, DAQplugin but it is still the same, doesnt save/load Trackmaps and when I want to select any laps from Data it shows me all laps in one, f.e. when I've done 30 laps it shows me all in one lap.
I hope you guys can help me out! Thank you so far, and sorry about my poor english.
EDIT: I have also tried this already
And I just want to say, that MoTeC has had done it on its own before, so it cant be the problem here.
You will have to use lap editor to create start and finish points in your data. Track mapping only works in Circuit Project and requires a "Trusted" Lap therefore creating lap beacons is the key.
