Brake Bias discussion
PostPosted: Fri Aug 06, 2010 7:32 am
by Martin
I think It would be interesting to see bias scatter plots from different pedal box setups. This is an AP reversed Pull Pedal box.
Re: Brake Bias discussion
PostPosted: Fri Aug 06, 2010 2:39 pm
by JamieA
A Modified Ford Escort standard pedal box with brake bias added. Very ordinary.
V8 supercar setup. - Custom made floor mount pedal box.
v8 supercar brakebias sml.jpg (38.83 KiB) Viewed 15411 times
PostPosted: Fri Aug 06, 2010 2:48 pm
by JamieA
1972 Datsun 1200 coupe with Tilton hanging pedal box
Datsun1200 bbias sml.jpg (23.78 KiB) Viewed 15348 times
PostPosted: Fri Aug 06, 2010 3:27 pm
by Holmz
That is very sensible way to look at - thanks for the posts.
PostPosted: Sat Aug 07, 2010 7:53 am
by Martin
The very first post is of a car equiped with ABS. The abs tends to scatter the Bias a bit as it works.
I think a crossover type ABS will interfere less.
Jamie,
Is the V8 Supercar data Dash Calculated bias or I2Pro calculated data?
PostPosted: Sun Aug 08, 2010 7:02 pm
by Sean
AP floor mount pull type pedal box, ex v8 supercar, i2 calculated bias.
bias ham.jpg (56.78 KiB) Viewed 15231 times
Interesting stuff, looking at the bias plots for different runs and days. This car generally produces nice plots like above, but when the brakes get quite worn, the scatter increases noticably.
The second plot is a whole session from the same car. Started the run with new pads and new rotors, ended the run with badly warped front rotors, and the car off the track with no front brakes :cry: . It appears the new pad material we tried wasn't compatible with the pad material the rotors were bedded with.
bias ham 2.jpg (82.28 KiB) Viewed 15231 times
