Interpreter software for Windows 2000??
Tue May 11, 2010 6:29 am
by Chris Wilson
Can I use a version of the Interpreter software on a laptop running Windows 2000, to read data from an M800 running on the latest firmware and running the latest software for ECU calibration? What version of the standard Interpreter software do I need, and will I be missing much functionality? Thanks. I have some Bosch dignostics on the laptop that I often need, that won't run under XP.
Re: Interpreter software for Windows 2000??
Wed May 12, 2010 9:51 am
by JamieA
i2 will only work on Windows XP or newer, so that wont work.
the older interpreter will run on windows 2000, but I am not sure if M800 files will completely or correctly open in interpreter.
The log file format is mainly unchanged from the days of interpreter, but there is no guarantee that it will work.
-Jamie
Fri Aug 13, 2010 2:34 pm
by Data Recovery
You may try a tool-kit for it. It is available on the below URL. Hope these would help you out.
http://joule.ni.com/nidu/cds/view/p/id/1166/lang/en
Britt
Data Recovery Software
