Interpreter software for Windows 2000??
Postby Chris Wilson on Tue May 11, 2010 6:29 am
Can I use a version of the Interpreter software on a laptop running Windows 2000, to read data from an M800 running on the latest firmware and running the latest software for ECU calibration? What version of the standard Interpreter software do I need, and will I be missing much functionality? Thanks. I have some Bosch dignostics on the laptop that I often need, that won't run under XP.
Chris Wilson
Re: Interpreter software for Windows 2000??
Postby JamieA on Wed May 12, 2010 9:51 am
i2 will only work on Windows XP or newer, so that wont work.
the older interpreter will run on windows 2000, but I am not sure if M800 files will completely or correctly open in interpreter.
The log file format is mainly unchanged from the days of interpreter, but there is no guarantee that it will work.
-Jamie
JamieA
Postby Data Recovery on Fri Aug 13, 2010 2:34 pm
You may try a tool-kit for it. It is available on the below URL. Hope these would help you out.
http://joule.ni.com/nidu/cds/view/p/id/1166/lang/en
Britt
Data Recovery Software
Data Recovery Services
Data Recovery
