Value Decreases
Value Decreases
Postby Sqiushy on Thu Feb 25, 2010 9:21 am
Hi there,
I hope you can help me.
I am trying to create a expression that only plots an decrease in a value. eg. Lets say for example that i want to plot the movement of suspension only if the travel is moving in a negative direction.
I know i have to start with a 'choose' statement but i am not sure how to 'get' the position of the suspension if it is moving in a particular direction. Just to clarify, I dont want the suspension position between two values, i want the suspension plotted if it moves in X direction.
I know that might not make perfect sense
Any thoughts would be welcome.
Take Care
SQ
Sqiushy
Re: Value Decreases
Postby Fermin on Sun Feb 28, 2010 1:15 am
Maybe it is your solution (v1.05 i2pro):
SuspPosFLSuav20: smooth('Susp Pos FL' [mm],20)
SuspPosFLSuav20_travel_positive_direction: (1/(derivative(smooth('Susp Pos FL' [mm],20)) > 0)) * smooth('Susp Pos FL' [mm],20)
SuspPosFLSuav20_travel_negative_direction: (1/(derivative(smooth('Susp Pos FL' [mm],20)) < 0)) * smooth('Susp Pos FL' [mm],20)
or if you prefer the function choose:
SuspPosFLSuav20_travel_positive_direction:choose(derivative(smooth('Susp Pos FL' [mm],20)) > 0, smooth('Susp Pos FL' [mm],20),1/0)
SuspPosFLSuav20_travel_negative_direction:choose(derivative(smooth('Susp Pos FL' [mm],20)) < 0, smooth('Susp Pos FL' [mm],20),1/0)
Fermin
Re: Value Decreases
Postby Sqiushy on Fri Mar 05, 2010 12:28 am
Perfect, thanks a lot.
Good stuff there, got me thinking
Thanks again.
-SQ
Sqiushy
