Well, phooey -- I guess that would have been too easy.
OK, I downloaded the sample data file and accompanying video. I tried the test on the system with the KF CPU (no onboard gfx) and the GT+1080Ti system. Same results on both.
Here's the notes I took as I went through the steps:
- copied files to c:\Motec and c:\motec\video
- open i2pro, confirm version 1.1.4.454
- create new workspace (circuit, otherwise default)
- removed my own video dir from tools->options video sources list
- added c:\Motec\video back onto that list
- let the "video processing" spinner finish
- close i2pro
- open i2pro, select newly created workspace
- load data from sample session in c:\Motec
- samples-graph tab, reduced size of strip chart to make room
- right click, add component in blank space and choose video
- component appears with message: no video configured for '' camera view. [<- that's verbatim including quotes]
- properties dialog opened automatically for me, view drop down shows "Camera Number 0"
- hit edit button in the properties dialog
- initially Camera Number 0 line is highlighted but below that the correct video file is listed. Preview window blank.
- click on video file name, video appears in preview window and it will play there
- stop preview, close button, ok button in video properties
- select video component window to foreground, hit "a" key...audio but no video in the component window
As I say this happens practically(*) the same on both systems if I have i2pro on a screen connected to the NVidia cards. Not sure if this helps but...when I tried this on the system with two screens attached, one to NV and the other to the onboard, after I saw the video missing on the NV screen I dragged the i2pro window with the (animation paused) onto the other screen and then restarted the animation...the video and audio both play fine in that scenario.
[* when I say practically the same, the view list shows differently on the Gt/Ti1080 system -- this is an older more used i2pro install and I've had to tinker with the camera view properties now and then to get video to show...for some reason I don't always get video without by-hand associating the video files...probably user error of some kind but I haven't been able to figure out a pattern. At any rate in that system's video component property dialog when I click the view drop down I typically see views named "Default", a blank named one and then "Camera Number 0" which is where I usually see i2pro has put the video from the source directory. If I delete the "Default" and blank line entries to tidy up, video will work (on a non-NVidia system!) but next time I open the same session after restarting i2pro the two unused entries magically come back...this seems...counter-intuitive. I've tried to read as much as I can into the instructions/help for the video component properties but I'm still not totally clear on how all the capabilities are supposed to work together in there...which is likely why it looks a bit messed up. If you happen to know of a description/video of how one's workflow around the video component properties should best be used, that would really be handy for me. As one piece of UI design feedback, it's really odd to have a dialog with a close button but not a cancel/ok choice...does close always imply OK in this case?? Does the red X have different semantics for this dialog (as in will that discard changes)?? Sorry, I know I digressed but this video component is the one i2pro UI element that leaves me scratching my head sometimes, maybe because the rest of the program is pretty darned good/consistent
