i2 Google map error
Re: i2 Google map error
Postby john_r on Thu Jul 05, 2018 11:15 pm
I remove my key, but the map still does not open.
I get the same error messages, and I can also open the link in chrome or on the command line with the help of a curl.
Code: Select all
05.07.2018 15:10:18:    Retrieve Google Map: http://maps.googleapis.com/maps/api/staticmap?center=50.356174%2C30.270151&zoom=15&scale=2&size=640x640&maptype=satellite&sensor=false&key=AIzaSyCA54h8FtbTgvl3KpPgvUdjGQ-3Kf7RgTY
Thanks for the "Trying to reset... ", the problem is solved.
john_r
Postby adrian on Fri Jul 06, 2018 10:26 am
What version of Windows are you using? Do you have a proxy server setup?
Postby john_r on Sat Jul 07, 2018 12:51 am
Windows 10 Pro x64
Yes, the problem was in the proxy settings, but it's pretty strange.
In the Internet Explorer (classic) settings there was an entry for the socks proxy, which is not currently available, but the checkbox "use proxy server" was removed.
I set a check box, deleted the record about the socks proxy, remove the checkbox and it all worked.
I checked it again: I2 use proxy settings, despite the fact that the "use proxy" checkbox is cleared.
Thanks for the help, now everything works. With my Google API key also works.
john_r
Postby adrian on Mon Jul 09, 2018 10:44 am
Thanks for letting me know. We will have a look into whether there is anything we can do in this area but unfortunately we are at the mercy of Windows and there maybe nothing we can do.
