Showing map with log
Re: Showing map with log
Postby Brian on Thu Aug 03, 2017 8:12 pm
Just started working with a MoTeC system fitted in a 997. Using the driver's PC at the track, I have the track map at the bottom of the Values list. I took the files home on a stick, downloaded i2 Standard on my own PC and got started with the program. I can view all except I cannot get the track map on the values list in any of the worksheets ( Found the "Show Track" button at the top of the values list but this did not help). I can load the the track map in the Track Report Worksheet ( Right Click ->Add -> Track Report).
Any ideas how to proceed??
Thanks,
Brian.
Brian
Postby David Ferguson on Fri Aug 04, 2017 8:15 am
You probably need to remake the map using Tools->Track Editor->Generate Track... Be sure to select a valid lap, sometimes the automatic track creation will use a non-valid lap becuase it has the fastest lap time.
Also, if your values window has lots of channels, you might need to "pull up" the bottom divider to reveal the track map.
Postby Brian on Sat Aug 05, 2017 2:48 am
Hi David,
Yup, pulling up the bottom divider does the trick (Duh..... :oops: )
Thanks,
Brian.
Brian
