Zero Sensors??
Zero Sensors??
Postby Brinkley on Tue Dec 21, 2010 12:39 pm
First let me say thank you for the webinars, I have not logged on to a live meeting but have watched all of the presentations from archives.
I do not know if this is an ECU or i2 questions but here it goes. I have a M800 and SDL using i2 Standard. I am running a "fly by wire" '04 Porsche 996 motor so the throttle body is controlled via computer NOT throttle cable. I have noticed during recent races that the throttle position is being logged at 97-98% when I believe it should be 100% (straight away). In past races at the same track I have shown consistent 100% throttle positions on i2.
When I am in ECU Manager there is a "Zero Sensors" icon, what does this button do? and if I hit it will it re-zero my throttle sensor so that I might get to the 100% when the peddle is on the floor?
Thanks for any advice you can provide.
Brinkley
Re: Zero Sensors??
Postby Sean on Fri Dec 24, 2010 7:50 am
I would suggest you re post this in the M800 forum, i2 is reporting what the ecu tells it. I have no experience with DBW, so I would only be guessing on the correct way to set the open and closed throttle.
Sean
Re: Zero Sensors??
Postby Brinkley on Fri Dec 24, 2010 11:46 am
Sean,
Thanks for the suggestion. I'll do that.
Brinkley
Users browsing this forum: Bing [Bot] and 6 guests
