Writing a Coasting Math w/ i2 Standard
Postby Brinkley on Wed Mar 11, 2009 10:07 am
I am using i2 Standard and have the latest updates. I have been writing Maths for different functions and now would like to write a Math for Coasting. The goal is to chart when I am off the throttle from 5% down to 0% and NOT on the brakes above a certain %.
First, can a Math like this be written with i2 Standard? If so can someone help me with the steps and formula?
Thanks for all and any help provided.
Brinkley
Re: Writing a Coasting Math w/ i2 Standard
Postby Holmz on Wed Mar 11, 2009 10:50 pm
Brinkley wrote:Hello,
Brinkly,
What exactly are you hoping to get numbers on in terms of coasting?
I am doing the same so I can help with the math.
Also got the details on the PID - but am in the process of redoing a loom.
I would really like to transition to this inside the data logger itself after I get it running in i2 as a post-processing maths function.
What data do you have? You will need:
1) Speed, and if you are on a non-flat surface then position including altitude, a pitch gyro may also be useful.
2) Mass of the vehicle
3) Some way of identifying the coasting (neutral would work - or the 0%-throttle/0%-brake is a good approach. I will likely want to go for a switched input, or see if It can break the data out into a separate file.)
We'll probably be learning in parallel - so...
Where are you located - send me a PM.
Holmz
Postby Brinkley on Thu Mar 12, 2009 9:00 am
You asked what am I looking to get numbers on? Well this type of math seems to be common a Motec distributor showed me his Math: BrakePresFront(psi)<Brakethreshold(psi)ANDThrottlePos(%)<ThrottleThreshold(%). The Threshold (constants) where Brake Threshold 25psi and Throttle Threshold 5%.
This Math gives him a strip chart of short flat plateaus at the end of each straight that indicate when he is not on the throttle above 5% and not on the Brakes over 25psi. The visual chart helps highlight when the driver could be either on the throttle more or on the brake more.
That is what I am trying to accomplish.
I have Throttle position (%), I don't have Brake Pressure, but will substitute Negative Longitudinal G's from 0 to -.15G's. This will have to work until I install a brake pressure sensor. My problem with his math is he can assign Constants and I can't figure out how to do that with i2 Standard. I believe it might be impossible without moving to i2Pro.
Brinkley
