How do I back up a colour scheme?
Postby WozzaUK on Mon Jul 30, 2018 7:23 am
I made a colour scheme in Motec and saved it in the usual way but when I wanted to do a system reinstall I couldn't find where it was saved and I lost it.
Is it saved somewhere so I can make a backup copy next time?
Thanks, :)
WozzaUK
Re: How do I back up a colour scheme?
Postby adrian on Mon Jul 30, 2018 11:04 am
The colour scheme files are located here: C:\Users\<Username>\Appdata\Roaming\MoTeC\i2\1.1. There is a .mcs file for each custom colour scheme you have. You can back these up and then copy them to the same folder after the fresh install.
I am going to add a feature request to our system to make it a bit easier to export these out within i2 itself so you don't have to manually go hunting for the files.
Adrian
Postby WozzaUK on Sat Aug 04, 2018 4:08 am
Many thanks, Adrian. That worked. :D
WozzaUK
