EMAP Sensors - choosing the right sensor
I am having failure issues using two of the Honeywell 100psi sensors for EMAP sensors on my race car. I have used the sensors in the past with success but I'll list a few reasons I think they might be failing:
Peak pressures from cylinder pulses are obviously over 100psi although very brief could this cause a failure. My EMAP is usually around 26psig
"backfires" - rarely happen but maybe it doesn't take much.
EGTs in the 1500*F range - although I have run close to 3ft of stainless tube from the source and the tube is mounted to a heat sink that is bolted to the chassis with heat dissipation paste (like on a ignitor). Ambient temps around the sensor are in the 150* range.
I custom blend my own fuel, it is a mixture of ethanol and toluene, my turbine wheel looks brand new so obviously it is fairly caustic.
There are a few things I could try, the easiest of which I am thinking is the 500psi TI "Nitro" sensor. It would allow me to just swap sensors without changing anything other than the sensor cal table, resolution might suffer though. What is everyone else doing? If it makes any difference one sensor still works, the other failed slowly. It would start reading lower than the other (causing me at first to look for mechanical issues) but it quickly started to get lower and lower without any difference the power output so I knew it was the sensor. It has now completely failed and I have noticed that the "good one" now reads 95kpa at atmospheric (usually reads 100.x around here) which makes me think it's on its way out.
