2 sets of DMCD's fried
Postby Ben-S on Mon Jun 08, 2009 12:49 pm
I'm using two DMCD's as converters for the abs sensors on my Honda S2000 and have now gone through a total of 4 of them. I will check the VPP and Amp output of the stock sensor tomorrow (did not have the equipment where this set went out). I normally use gear as the 4d axis and traction control so it's a pretty big issue. I can't imagine the stock sensors are putting out over 120Vpp or 5A. Has anyone else had this type of issue?
Ben-S
Re: 2 sets of DMBD's fried
Postby Martin on Mon Jun 08, 2009 4:29 pm
Whats a DMBD? Is it like a DMC? (Dual Mag Coneverter)
Re: 2 sets of DMCD's fried
Postby Ben-S on Tue Jun 09, 2009 12:42 am
DMCD sorry.
Ben-S
Postby Ben-S on Thu Jun 11, 2009 12:52 am
Voltage confirmed to be well under 120Vpp (not even half that). Interesting thing is I have had 4 of these and one of the original ones still works while the other 3 do not work at all.
Ben-S
