DBW4 Wiring
PostPosted: Fri Mar 27, 2009 5:04 pm
by Martin
I have found in previous installations that supplying an ECU with an insuffiecient gauge wire makes the DBW throttle jitter. The DBW4 only has one 22g pin per DBW output, would this be a problem is the DBW throttle is 3m from the DBW4?
All of the 6 12v pins and all of the 7 earth pins will be connected (22g wire)
M
