Duel Mag Converter on a Nissan
PostPosted: Sat Feb 28, 2009 11:24 pm
by garykenward
Hey guys, Anyone using a Dual Mag Converter on a nissan...?
I want to use the front ABS Mag sensors linked through a DMC for traction controll, but I dont know if the OEM ABS sensor puts out the correct voltage for the DMC to work properly...Im running a 98' 200sx/silvia SR20DET.....
I know that the resistance across the sensor should be between 0.6 and 3.3k/ohms(according to the workshop manual, I dont know if this helps at all, but hey.....) I cant test the output of the Mag sensor because the engine is out. Any advice is much appreciated. Thanks.
Re: Duel Mag Converter on a Nissan
PostPosted: Fri Aug 21, 2009 1:07 pm
by Pascal
Hey Gary,
I am after same thingy. S13 with S15 enigne and lower train. Need that for lounch control and anti-spin. Any news maybe??
Cheers!
