DBW4 MXXX setup
Are there any details available on the setup of a DBW4 from the MXXX point of view? The setup document for the DBW4 only details the setup from the DBW4 side of things.
Things like (but not limited to):
And also, is there a CAN template for things like ADL3/SDL3/CDL3 to process the CAN data from a DBW4?
Cheers,
Ben
- How do I tell an M880 to use the DBW4 for DBW instead of the onboard DBW (via AUX1/2)
- How do I tell an M880 how to use DBW4 for idle speed control (instead of on board DBW)
- How do I map the inputs from the DBW4 for TP/TP2 into TP/TP2 on the M880 (the drop down list for sensors only lists the on board sensor inputs, EX(888/816) A* inputs, MDD inputs, ADL inputs and a couple of other random inputs, but no DBW4 inputs (despite selecting 7/8 for Can 2 / Can 3).
- Is selecting 7/8 on the CAN comms settings all that is required to enable a DBW4?
- Etc
Cheers,
Ben
