Dual Half Bridge (DHB) with 2 SPAL brushless fans
Posted: Wed Aug 30, 2017 12:30 pm
Hi all,
I have dummy questions for the smart people to help me out here. I would appreciate your inputs.
A bit of background, I have M150, PDM30, DHB and 2 SPAL brushless fans. I wish to control the fans with DHB but here are my concerns. Each fan would require between 15 to 20 continues amps, that would total up to 40 amps. As I understood from the DHB, it has maximum of 20 continuous amps and this worries me.
According to the instructions as I understood it, it has one input from ECU, one output to the fan and one power input.
Each fan has 4 wires, Black/Red for power, white & yellow for the PWM signal (I guess)
Based on my understanding, the power is connected to DHB, but due to DHB amp limitation can I disconnect the power from DHB and connect Black/Red wire on the Fan directly to the battery?
Second question, the fan has 4 wires and DHB has only 2 output and I guess to yellow and white. Hence, black/red wires on the fan has no place to be connected to DHB. Then why do you need to power DHB since the Fan is powered directly?
Or is this power only to amplify the PWM signal and DHB will always require power not to power the fan, but only to amplify the PWM signal? so in this case, what would be the consumption of the PWM signal for the 2 brushless fans?
Thanks,
Abdulla
Thanks,
Abdulla
