M48 USB controller wiring pinout...
Postby NiTeC on Thu Jan 15, 2009 8:06 am
Hey guys...wondering if anybody has some ideas...
I am trying to use this serial2usb controller: DLP-TXRX Internal USB
however it uses the Tx - Rx D9 connections (pin 2 and 3) where the M48 uses pins 9 7 5 1 (RI RTS GND DCD)...
is there a way I can make this work?
NiTeC
Location: In front of the car admiring the intercooler...
Re: M48 USB controller wiring pinout...
Postby RossB on Thu Jan 15, 2009 8:44 am
You would need to use it with a MoTeC PCI Cable on an M48. The PC end of the PCI cable uses the standard serial pins.
Postby NiTeC on Sun Jan 18, 2009 5:44 am
hmmm..
wired everything up, all connections test ok, setup the converter to COM1 and it still says not connected...
is there a way to make Motec connect on a different com other than COM1?
thanks for the help btw...
NiTeC
Postby NiTeC on Sun Jan 18, 2009 6:31 am
I keep trying to get this to work..
If I try to manually set the COM settings in DOS (I disabled the serial port in BIOS to avoid confusion) using the MODE command I can get the following setup:
Baud: 9600
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: OFF
XON/XOFF: OFF
CTS Handshaking: ON
DSR Handshaking: ON
DSR Sensitivity: OFF
DTR Circuit: HANDSHAKING
RTS Circuit: HANDSHAKING
I have wired the above mentioned controller AFTER the circuit that was on the original cable - I noticed that the input to that circuit are the MOTEC serial OUT - pins 1,5,6,7 and 9 but the output are pins 2,3 and 5 (RX, TX, Gnd)...so technically wiring those pins to the controller's inputs should work fine....the controller installs properly, it receives COM1 as assigned value and everything checks out - BUT MOTEC software just keeps saying the ECU is disconnected...
If I try to connect to the COM using Hyperterminal I cannot open a connection for Baud higher than 4800...
Any help is appreciated - I really want to make this more accessible through the USB port....
NiTeC
