E816 CJC Inputs
Tue May 31, 2016 2:11 pm
by LeoDelC
The manual for the E816 states the unit has two inputs for cold-junction compensation sensors (CJC1 and CJC2). When connected to my C127 dash, these input pins do not appear in the Connections Devices menu.
How do I configure the dash to read these inputs?
Re: E816 CJC Inputs
Tue May 31, 2016 3:39 pm
by adrian
You can't configure those inputs, they are designed to use Bosch 0 280 130 023/026 temperature sensors.
Re: E816 CJC Inputs
Wed Jun 01, 2016 2:04 pm
by LeoDelC
If I connect the specified sensor, how do I access the temperature reading of the sensor?
Re: E816 CJC Inputs
Wed Jun 01, 2016 4:31 pm
by adrian
In dash manager go to Connections>Communications, select the CAN bus you have the E816 connected to and then click select. Search for "Expander Diagnostics" and click OK. That template includes both of the CJ Comp channels as well as other diagnostics.
