Expander vs. DBW4
Expander vs. DBW4
Postby Denali on Sun Feb 03, 2013 2:28 am
i only have one throttle body to control, would a E816 be able to control it with the dbw ecu upgrade? my thought is that in the future the expander would be more useful on different setups and the DBW4 is for multiple throtle bodies.
Denali
Re: Expander vs. DBW4
Postby YuriK on Wed Feb 20, 2013 3:04 pm
If you upgrade the ECU with DBW option, you can drive one electronic throttle directly from the ECU, no DBW4 needed. What ECU have you got?
Thanks!
YuriK
Postby Denali on Thu Feb 21, 2013 12:10 am
its a M400 that will be running a Subaru STi engine (without adjustable cams)
thanks for the response Yuri
Denali
Postby YuriK on Thu Feb 21, 2013 1:54 pm
M400 will run one electronic throttle (with DBW upgrade installed), no DBW4 needed
Regards!
YuriK
