EHPS (electro hydraulical power steering) control
Has anyone used a Mxx ecu or SDL output to control an EHPS pump for the steering ?
Been toying with the idea of adding an electro hydraulic pump (Toyota MR2 late model) to the steering since the belt driven pump was ditched.
Anyone done a similar project or thoughts and ideas on how to go about it ?
Was thinking of running an output signal to the pump control unit from a 3D table of my SDL to speed control the pump on the VSS signal it normally pIcks up from the gearbox speed sensor.
Here is the link to the conversion process -http://www.mazdaspeedy.com/2011/11/toyota-mr-s-electric-power-steering.html
