MDD
Mon Jul 02, 2012 5:40 pm
by rems11
Hi Everybody
I have a probleme with my MDD.
I can't display on MDD drive speed and gear detection, while i have gear dectection and drive speed left with logs on my M800
All others mesures display except drive speed left and gear detection
Re: MDD
Mon Jul 02, 2012 5:50 pm
by JamieA
Have you verified whilst driving (with a passenger reading the connected laptop) that the "Ground Speed" channel, and the "Gear" channels are definately showing accurate readings?
it has to be those exact channel names...
regards,
Jamie
Re: MDD
Thu Jul 05, 2012 7:00 am
by rems11
Jamie
Gear detection is ok
Here my log
Re: MDD
Tue Jul 10, 2012 4:14 pm
by JamieA
how about the ground speed channel?
Perhaps email me your config so that I can test it here.
Jamie.augustine@motec.com.au
Re: MDD
Wed Jul 11, 2012 8:32 am
by rems11
I have sent you my config Jamie, thanks for your help
Re: MDD
Wed Jul 18, 2012 12:30 pm
by OmarK
Your ECU config is fine and is working, can you go for another drive, check if you can see gear and speed working and send us the log file from the ECU so we can take a look further.
Re: MDD
Sat Apr 22, 2017 9:40 am
by Paragon
I have the same problem with the gear not displaying but do have speed.
Was there ever a solution to this ?
MDD V1.14 M800 V3.54
Re: MDD
Mon Apr 24, 2017 7:24 pm
by adrian
I'm not sure what the original issue was but if you send your ECU config to
support@motec.com.au I can test it out for you.
Re: MDD
Sat Jul 22, 2017 3:38 pm
by Paragon
the solution is to get your MDD firmware upgraded. The problem is known and since the upgrade is not as easy as plugging in a UTC the MDD generally does not get upgraded after leaving the factory.
This solved the lack of gear position on my unit and a mates, 2 different old firmwares.
