MDD
MDD
Postby rems11 on Mon Jul 02, 2012 5:40 pm
Hi Everybody
I have a probleme with my MDD.
I can't display on MDD drive speed and gear detection, while i have gear dectection and drive speed left with logs on my M800
All others mesures display except drive speed left and gear detection
rems11
Re: MDD
Postby JamieA on Mon Jul 02, 2012 5:50 pm
Have you verified whilst driving (with a passenger reading the connected laptop) that the "Ground Speed" channel, and the "Gear" channels are definately showing accurate readings?
it has to be those exact channel names...
regards,
Jamie
JamieA
Re: MDD
Postby rems11 on Thu Jul 05, 2012 7:00 am
Jamie
Gear detection is ok
Here my log
rems11
Re: MDD
Postby JamieA on Tue Jul 10, 2012 4:14 pm
how about the ground speed channel?
Perhaps email me your config so that I can test it here.
Jamie.augustine@motec.com.au
JamieA
Re: MDD
Postby rems11 on Wed Jul 11, 2012 8:32 am
I have sent you my config Jamie, thanks for your help
rems11
Re: MDD
Postby OmarK on Wed Jul 18, 2012 12:30 pm
Your ECU config is fine and is working, can you go for another drive, check if you can see gear and speed working and send us the log file from the ECU so we can take a look further.
OmarK
Re: MDD
Postby Paragon on Sat Apr 22, 2017 9:40 am
I have the same problem with the gear not displaying but do have speed.
Was there ever a solution to this ?
MDD V1.14 M800 V3.54
Paragon
Re: MDD
Postby adrian on Mon Apr 24, 2017 7:24 pm
I'm not sure what the original issue was but if you send your ECU config to support@motec.com.au I can test it out for you.
Re: MDD
Postby Paragon on Sat Jul 22, 2017 3:38 pm
the solution is to get your MDD firmware upgraded. The problem is known and since the upgrade is not as easy as plugging in a UTC the MDD generally does not get upgraded after leaving the factory.
This solved the lack of gear position on my unit and a mates, 2 different old firmwares.
Paragon
