DHB question
DHB is wired per 2nd diag. found in the product datasheet, driving two grounded motors in the same direction.
If I just connect the power wires of the DHB to the battery. No wires connected to the inputs, should I get voltage from the DHB output wires?
I am getting 6.5 volts, and when I connect the output to the pumps, obviously they come on right away (ECU/IGN PWR OFF)
As soon as I disconnect the output connector and measure the voltage from the pins again, I get 12volts. Does not matter whether I have the input connector hooked up or not. Does not matter what Output I'm using from the M800 ECU either. If I disconnect it from battery and then reconnect, the voltage drops to 6.5 volts again. So as soon as I reconnect the connectors, the pumps just instantly turn on. Is there something wrong with my DHB? Thanks
