by Stephen Dean on Wed Jan 14, 2026 10:09 am
The Pump that is supplied in the kit is rated for 100% duty cycle operation, this is one of the reasons for using that pump, it has also been tested in a 12 hour endurance race where a hose fitting leaked at the start of the race and it was in a location that it couldn't be resolved in a pit stop, so the pump ran non stop for most of the race (38°C temps that day as well) without issues. There is a bleed off valve supplied in the kit that activates ~140psi.
What I see with a number of Paddle shift installations is that the Pump threshold and Hysteresis values are not set correctly, so that the pressure in the system fluctuates too much for a consistent shift. I have seen one that had a 100psi variance between the high and low pressures in the system, it didn't shift well down low.
