EHPS (electro hydraulical power steering) control
Includes expansion units, sensors, valves, wiring, communication cables etc.
Re: EHPS (electro hydraulical power steering) control
Postby Blu302 on Thu Sep 06, 2012 6:03 pm
Have you had a look at the Curtis AC/DC motor controllers? You could pair it up with a suitable truck/forklift hydraulic pump. It would do all the speed control for the hyd motor(CANbus/pot/voltage/frequency as the control signal). Also, don't Toyotas run an EHPS system?
Blu302
Blu302
Postby 20B on Mon Sep 10, 2012 10:56 am
Yes I ended up purchasing a late model Toyota MR2 pump as this seems to be the proven way to do it.
Just wanted to check first if anyone had done any kind of 'control' for it through a dash before.
Mazda 1993 RX7
20B N/A engine
20B
Postby 01-0041 on Thu Sep 02, 2021 12:41 am
Hello 20B,
Bringing this back from the dead!
Did you ever come up with a solution for the speed signal? I'm looking at doing something like this with my C125...
Thank you!
Trever
01-0041
Postby lurwun on Wed Feb 02, 2022 7:45 am
Martin wrote:20B
Ive used the Mini cooper Electro hydraulic pumps before and also the latest mini R56 powersteering pump that needs CAN data TXd to it to make it work. If you are interested in these pumps send me an email
THIS. Info?
01-0041 wrote:Hello 20B,
Thank you!
Trever
If you check OP’s website, you’ll find: “I also run a wire from the VSS signal of the ECU to the VSS terminal on the controller.”
lurwun
Previous
Return to Accessories and other MoTeC products
